crazy requirements - please help
Audio software developers forum.
mainto
Post by mainto » Tue Jul 15, 2014 3:38 pm
Hello,
I've got an issue that's been dropped on me somewhat and I'm looking for a nudge in the right direction. I've been looking at Audacity to solve my problem but I think it only partly does it.
I need to take .wav files, then cut them together into a sequence - Audacity helps with that I think?
Then when I have the final single files, I need to be able to convert them into Intel Hex ROM format so I can load them onto a flash memory card? What is around to help me do this? I used to use an old copy of Voicepro 3 but it has ceased to work.
Can anyone give me the name or a program that can convert the wav files into the Intel Hex format?
Hope someone can help, not really an audio guy but I've had a google around and most programs seem to be fine for dealing with more modern formats, but not older ones.
Cheers
Mani
Re: crazy requirements - please help
Post by steve » Tue Jul 15, 2014 5:13 pm
mainto wrote:I need to take .wav files, then cut them together into a sequence - Audacity helps with that I think?
Not sure what you mean by "cut them ... into a sequence". Do you mean "join them into a sequence" so that multiple files are concatenated (joined end to end) into one file?
mainto wrote:I need to be able to convert them into Intel Hex ROM format
"Intel Hex" is not an "audio format", it is a "data format".
http://en.wikipedia.org/wiki/Intel_HEX
The correct "audio format" depends on your application (the rest of your program).
Audacity can export in a number of audio formats. I'd guess that for embedding into a ROM you would want a low data rate format, possibly an 8 bit format such as A-Law PCM or u-Law, or a 4 bit format such as ADPCM.
http://en.wikipedia.org/wiki/G.711#A-Law
http://en.wikipedia.org/wiki/G.711#.CE.BC-Law
http://en.wikipedia.org/wiki/ADPCM
See here for more information about formats supported by Audacity:
http://manual.audacityteam.org/o/man/fi ... ialog.html
Audacity does not support "Intel Hex" format, so once you have the audio data in the correct "audio format" you will need to use some other application to convert the audio data into Intel Hex format (try searching Google for forums that are concerned with EEPROM / Microcontroller programming).
mainto
Post by mainto » Wed Jul 16, 2014 10:12 am
Thanks for your reply, yes, I meant joined in sequence, apologies for any confusion.
I'll have a look for an alternate program for converting into a suitable format, the files are being loaded onto vehicles via EPROM cards.
Thanks again.
