Separate setting for downwards and upwards compression
This read-only archive contains discussions from the Adding Feature forum.
New feature request may be posted to the Adding Feature forum.
Technical support is available via the Help forum.
Post by steve » Wed Jul 09, 2014 8:33 pm
Paul L wrote:It also appears to me that the upwardness or downwardness could really be independent of whether the envelope is defined by peaks or RMS, but the effect couples these features unnecessarily.
I agree that coupling upward/downward compression to peak / rms is unnecessary, and confusing having "make-up gain" which is actually "peak level normalization".
The compressor is known to be quite "quirky" (but it's a lot better than the previous one ;))
Paul L
Re: Separate setting for downwards and upwards compression
Post by Paul L » Mon Jul 21, 2014 7:44 pm
The noise floor feature is quirky too. I figured out it really means "stop raising the gain while sound is below the noise floor" but gain might be low or high coming into the noise depending on what precedes. Noise after quiet signal gets raised more.
waxcylinder
Post by waxcylinder » Tue Sep 23, 2014 4:44 pm
Is there a Feature Request lurking here :?
Peter
Post by Gale Andrews » Tue Sep 23, 2014 11:22 pm
waxcylinder wrote:Is there a Feature Request lurking here :?
Peter
I made a note of the votes, so archived.
