inadvertent change [SOLVED]
Feedback and Reviews for Audacity 2.x
This board is ONLY for general feedback and discussion about Audacity 2.X.
If you require help, or think you have found a "bug", please post on the forum board relevant to your operating system.
Norm Mast
Post by Norm Mast » Sun Jun 29, 2014 4:29 pm
While editing a file and adding track names I looked up to discover I somehow changed the appearance of the Audacity screen. I'll be the first to admit this is with the older version so if I get booted out of here I understand.
There are extras showing that were not there before. How do I go back to the 'original' view? Notice the dark blue lines at top & bottom of each track, the gray shaded area as well as the different markings at front and end of track. Other issues as well but will wait to see if this post will be permitted.
Re: inadvertant change
Post by kozikowski » Sun Jun 29, 2014 6:13 pm
You selected the Envelope tool. See that "I" beam up on top. Select that.
Norm Mast
Re: inadvertent change [SOLVED]
Post by Norm Mast » Sun Jun 29, 2014 6:43 pm
Thank you thank you!
Post by Gale Andrews » Mon Jun 30, 2014 12:50 pm
kozikowski wrote:You selected the Envelope tool. See that "I" beam up on top. Select that.
Actually he selected Multi-Tool which includes Envelope Tool.
If you select Multi-Tool that choice is saved to audacity.cfg, so restarting Audacity does not get you out of the problem.
