I just started trying to use Audacity to put my cassette tapes on CD's. I recorded a tape and was able to play it back after recording it but couldn't seem to get it to where I could burn it onto a CD. Now 2 days later I can't seem to find anything.
Hope someone can help me on this. I am using windows 7
trying to burn cassettes to CD
Re: trying to burn cassettes to CD
Export the recording as WAV and burn it with CD burning software. You can't burn a CD directly from Audacity.
- Quality Assurance
If you were looking for the documentation it's at Burning music files to a CD - Audacity Manual .
