Is tthere any way to use three headphone to record our voicd
Tabish khan
Post by Tabish khan » Thu Jun 12, 2014 9:10 am
In need to record voice can i use three headphone at a time to record three voices because i need it urgently for my project can you give me some advice.
Re: Is tthere any way to use three headphone to record our v
Post by steve » Thu Jun 12, 2014 1:10 pm
Headphones are for listening, microphones are for recording.
Assuming that you mean "headsets" (combined headphones and mic), you would need to use analog (NOT USB) headsets and either a multi-channel sound card (such as an M-Audio Delta 1010LT) or a mixer. Note that computer headsets will not work with either of these - you would need headsets with proper XLR audio connections:
http://www.cybermarket.co.uk/images/pro ... 1_566a.jpg
Probably a lot easier (and much less expensive) for the three of you to huddle around one microphone.
Alternatively you could try using a DAW application that supports ASIO, such as Reaper, but that is not our product so you would need to use their forum for support.
