Truncate silence.
Help for Audacity on macOS.
jb9
Truncate silence.
Post by jb9 » Wed Jun 04, 2014 10:58 am
Truncate silence. The way I understand the word truncate, and the way it seems to behave from briefly playing with it, truncate means delete some of the silence. **** hell. Surely the issue here is gobsmackingly obviously before I even type it. We don't want to truncate this silence, we want to DELETE IT ****.
Cheers, thanks. Why do we have to type this stonkingly obvious ****?
Reason: expletives "bleeped"
Re: Truncate silence.
Post by steve » Wed Jun 04, 2014 5:50 pm
Truncate
definition: to shorten by cutting off a part; cut short
jb9 wrote:Why do we have to type this stonkingly obvious ****?
I've no idea why you felt compelled to post that :?
We do our best to keep this forum family friendly, so please try to avoid typing expletives.
Post by Gale Andrews » Thu Jun 05, 2014 1:14 am
Truncate Silence (in version 2.0.5) never actually deletes the entire silence it detects, because it is limited to truncating silence to 1 millisecond. That limitation will be removed in the next 2.0.6 version of Audacity, but nonetheless it isn't simply a "delete silence" feature because it has the option of shortening (but not removing) the detected silence.
