Share your Audacity/Nyquist plug-ins here, or test drive the latest plug-ins submitted by Audacity users.
After testing a plug-in from this forum, please post feedback for the plug-in author.
- Quality Assurance
Post
by Gale Andrews » Thu Apr 27, 2017 3:28 pm
planetlizz wrote:If anyone knows the default numbers top to bottom, Id dig you!!
Trebor showed you the default values, but it is easy to get back to the defaults if you need to. Click the "Manage" button, expand "Factory Presets" then click "Defaults".
Trebor
- Operating System: Windows 8 or 8.1
Post
by Trebor » Thu Apr 27, 2017 3:42 pm
Gale Andrews wrote:... it is easy to get back to the defaults if you need to. Click the "Manage" button, expand "Factory Presets" then click "Defaults".
Since 2-1-3 I get an error message when clicking the default on Paul-L's DeClicker :
it attempts to load the settings from a compressor plugin ...
- DeClicker error message when default selected (since V2-1-3).png (22.21 KiB) Viewed 1847 times
If you've adjusted the DeClicker from the default settings, those settings persist during that session of Audacity when you try to return to default settings. The default settings only return after restarting Audacity.
Trebor on Thu Apr 27, 2017 3:52 pm, edited 1 time in total.
- Site Admin
Post
by steve » Thu Apr 27, 2017 3:50 pm
Trebor wrote:Since 2-1-3 I get an error message when clicking the default on Paul-L's DeClicker :
Click "OK" in that dialog, and run the effect.
Now open the effect again - do you still get that message?
- Quality Assurance
Post
by Gale Andrews » Thu Apr 27, 2017 4:10 pm
Trebor wrote:Gale Andrews wrote:... it is easy to get back to the defaults if you need to. Click the "Manage" button, expand "Factory Presets" then click "Defaults".
It does not happen to me on Windows 10. You may need to exit Audacity and delete pluginsettings.cfg, and perhaps delete pluginregistry.cfg as well (especially if you have multiple copies of the shipped Audacity plugins in the Effect Menu).
Trebor
Post
by Trebor » Thu Apr 27, 2017 4:36 pm
steve wrote:Click "OK" in that dialog, and run the effect.
Clicking "OK" doesn't make any difference : the default setting is not applied ...
- click on this animation to see it in its entirety
- DeClicker error message when default selected.gif (254.45 KiB) Viewed 1848 times
Trebor
Post
by Trebor » Thu Apr 27, 2017 4:47 pm
Gale Andrews wrote:... delete pluginsettings.cfg ...
That's fixed it , (but that does also delete all the presets for the other plugins).
- Site Admin
Post
by steve » Thu Apr 27, 2017 5:27 pm
I've an idea what may be happening.
@Trebor, could you try this test to see if it causes similar symptoms.
Here are two versions of a very simple 'effect' plug-in. It just tells you what value you selected.
Both plug-ins have the same name and the same file name, so you'll need to keep careful track of which is which.
- AAAtest.ny
- AAA Test version 1
- (236 Bytes) Downloaded 69 times
- AAAtest.ny
- AAA Test version 2
- (241 Bytes) Downloaded 64 times
Install "version 1" and run it.
Close Audacity.
Replace the "version 1" file with the "version 2" file.
Restart Audacity and re-test the plug-in.
Trebor
Post
by Trebor » Thu Apr 27, 2017 6:46 pm
steve wrote:@Trebor, could you try this test to see if it causes similar symptoms.
"AAA Test version 1 (236 Bytes)" no error message , default setting (5) works.
"AAA Test version 2 (241 Bytes)" generates this error message when selected from menu ...
- error message.png (6.33 KiB) Viewed 1846 times
same error message shown when selecting default on version 2.
So that looks like the same type of fault as was happening with Paul-L's DeClicker (& DeEsser).
- Quality Assurance
Post
by Gale Andrews » Fri Apr 28, 2017 3:46 pm
I get the error on first launch of the replaced AAAtest about not being able to load the setting of "5", but that part seems totally expected to me. That error only appears once.
The error clicking on defaults is repeatable, so I guess the issue is that Audacity does not check to see if the defaults actually changed and if so update the defaults.
Code: Select all
[pluginsettings/base64\:RWZmZWN0X055cXVpc3RfU3RldmUgRGF1bHRvbl9BQUEgVGVzdA\=\=]
[pluginsettings/base64\:RWZmZWN0X055cXVpc3RfU3RldmUgRGF1bHRvbl9BQUEgVGVzdA\=\=/private]
[pluginsettings/base64\:RWZmZWN0X055cXVpc3RfU3RldmUgRGF1bHRvbl9BQUEgVGVzdA\=\=/private/FactoryDefaults]
Parameters=val="5.000000000000"
Initialized=1
[pluginsettings/base64\:RWZmZWN0X055cXVpc3RfU3RldmUgRGF1bHRvbl9BQUEgVGVzdA\=\=/private/CurrentSettings]
Parameters=val="0.500000000000"
It should be:
Code: Select all
pluginsettingsversion=1.0
[pluginsettings]
Initialized=1
In Trebor's original case, pluginsettings.cfg seemed to be reading settings from another effect. If you were careful, it would have been possible just to delete that one bad entry in pluginsettings.cfg, but users should not be expected to have to do that.
steve wrote:I've an idea what may be happening.
AAAtest.ny
AAAtest.ny
Close Audacity.
- Site Admin
Post
by steve » Fri Apr 28, 2017 5:09 pm
Gale Andrews wrote:I guess the issue is that Audacity does not check to see if the defaults actually changed and if so update the defaults.
It doesn't, and what's worse, it retains the default setting even if the plug-in is removed (either via the Plug-in manager, or physically removed).
A possible fix might be to unset the "initialized" token when a plug-in is removed, or 'missing'. This could allow the last used and custom presets to be retained in case the plug-in is added back later, but would force the defaults to be reinitialised. I've not yet worked out how to do that, but I'd say it's a 'bug'.
