Hard Limiter not available while Editing Chains...
Paul L
Post by Paul L » Mon May 19, 2014 2:30 am
... why not?
Re: Hard Limiter not available while Editing Chains...
Post by steve » Mon May 19, 2014 12:45 pm
Because currently only built in effects and Nyquist plug-ins are supported in Chains.
http://manual.audacityteam.org/o/man/ch ... ation.html
Paul L
Post by Paul L » Tue May 20, 2014 1:38 am
Um... if it's neither "built-in" nor Nyquist, then what is it? There is a third kind?
Post by steve » Tue May 20, 2014 7:56 am
It's a LADSPA plug-in: http://www.ladspa.org/
There are also VST plug-ins (mostly Windows) and Audio Units (AU) plug-ins (Mac only).
The "Plug-ins and Libraries" page on the main Audacity web site says a bit about different plug-in types: http://audacityteam.org/download/plugins
For detailed information, including descriptions of all effects that are shipped as standard, see the Effects section in the manual: http://manual.audacityteam.org/o/man/effect_menu.html
Paul L
Post by Paul L » Tue May 20, 2014 1:46 pm
Thanks.
I see Noise Removal is available for chains, but the parameters are not listed. I Have not tried It in a chain yet. It also has that frst step which is dependent on selection. I am not sure what to expect if I try it.
Post by steve » Tue May 20, 2014 2:04 pm
  • If a Noise Profile exists, that Noise Profile will be used.
  • If a Noise Profile does not exist:
    • If the Chain is applied to files, the first file (all of it) is used to create the Noise Profile.
    • If the Chain is applied to the current project, the current Selection is used to create the Noise Profile.
pcspeak
Post by pcspeak » Tue Jun 17, 2014 11:06 pm
waxcylinder
Post by waxcylinder » Wed Jun 18, 2014 9:50 am
I've updated the alpha 2.0.6 documentation, the Noise Removal Page, with this - and added a link back to that from the Chains page.
