Audacity won't start on Ubuntu 13.04
Please state:
Please state:
Audacity will no longer start on my Ubuntu 13.04 desktop. I've tried... it just popped up! I had it running without a main window showing for a long time. I even registered for this forum, confirmed my registration, put the new login into Lastpass, etc. *while* the main window did not come up. Then, magically it popped up? That was way too long of a start up. I will try again here in a second...
OK I closed it and restarted. It took literally 4 minutes and 27 seconds from the time I typed in audacity until the window appeared! What's causing that?
Re: Audacity won't start on Ubuntu 13.04
Audacity tends to be "a bit slow" launching on Ubuntu, but I absolutely agree that is way too long.
Try launching Audacity from a terminal window:
Open a terminal window and type
then press Enter.
A load of stuff should come up while Audacity looks for available audio devices and for additional libraries. Watch to see if it hangs at a particular point.
Copy and paste the information into your reply and describe where it is pausing.
Also, when it has launched, open "Help > Show Log" and copy / paste that information into your reply.
Code: Select all
audacityA load of stuff should come up while Audacity looks for available audio devices and for additional libraries. Watch to see if it hangs at a particular point.
I did launch it from a terminal. Here's what I see for like the first 4 minutes:
I guess the question would be "what exactly is it thinking about for 3 minutes and 59 seconds before it moves forward?"
Code: Select all
Earth:audacity
(process:15784): GLib-GObject-WARNING **: Attempt to add property GnomeProgram::sm-connect after class was initialised
(process:15784): GLib-GObject-WARNING **: Attempt to add property GnomeProgram::show-crash-dialog after class was initialised
(process:15784): GLib-GObject-WARNING **: Attempt to add property GnomeProgram::display after class was initialised
(process:15784): GLib-GObject-WARNING **: Attempt to add property GnomeProgram::default-icon after class was initialised
ALSA lib pcm_dmix.c:1022:(snd_pcm_dmix_open) unable to open slave
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
bt_audio_service_open: connect() failed: Connection refused (111)
ALSA lib pcm_dmix.c:961:(snd_pcm_dmix_open) The dmix plugin supports only playback stream
Oh, I guess I should also post what gets written to the terminal after the 4 minute wait and just before the window actually pops up...
BTW does each and every post need to be approved and an email gets sent to me? Seems annoying...
Code: Select all
Earth:audacity
- Quality Assurance
The restrictions are due to spammers. We make sure posters get a track record of legitimate posts before we lift the restrictions.defaria wrote:BTW does each and every post need to be approved and an email gets sent to me? Seems annoying...
- Quality Assurance
Those two outputs look identical.
You didn't post the log that Steve requested.
Does it take 20 seconds between each line on that output or does it hang on one particular of those lines?
Did you change anything on your system since this problem started? Have you added a bluetooth device?
Sorry about the second post. Those lines come out fairly fast, then it pauses for the 3 minutes. Then this set of lines come out, fairly fast, then a brief pause and finally the main window launches. While this is happening the blue light on my web cam comes on for a while, blinks sometimes, stays solid for a while, etc.
And here's what's in the log
I know this wasn't asked for but I saw an "Audio Device Info" selection under help. When I select that I get a lot of output at the terminal window:
And the following in a dialog box:
I don't use Audacity often. I think it's been doing this for a while. In fact I thought it was just broken since it took 4 minutes to start I usually gave up. But this time I ran it and it got stuck, I went on the net looking for an answer when to my shock it popped up the window! The system has not changed hardwarewise. Of course the system has had many updates as I run the update-manager most days and install just about whatever comes along needing an update. I don't believe this desktop system has any bluetooth hardware at all. If it did I'd probably use it.
Code: Select all
Expression 'stream->playback.pcm' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 4541
Expression 'ret' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 1670
Expression 'AlsaOpen( &alsaApi->baseHostApiRep, params, streamDir, &self->pcm )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 1830
Expression 'PaAlsaStreamComponent_Initialize( &self->capture, alsaApi, inParams, StreamDirection_In, NULL != callback )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 2092
Expression 'PaAlsaStream_Initialize( stream, alsaHostApi, inputParameters, outputParameters, sampleRate, framesPerBuffer, callback, streamFlags, userData )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 2764
Code: Select all
07:21:27: Audacity 2.0.3
07:25:55: Retrieving FFmpeg library version numbers:
07:25:55: AVCodec version 0x352300 - 53.35.0 (built against 0x352300 - 53.35.0)
07:25:55: AVFormat version 0x351501 - 53.21.1 (built against 0x351501 - 53.21.1)
07:25:55: AVUtil version 0x331602 - 51.22.2 (built against 0x331601 - 51.22.1)
Code: Select all
Expression 'parameters->channelCount <= maxChans' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 1438
Expression 'ValidateParameters( outputParameters, hostApi, StreamDirection_Out )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 1780
Expression 'AlsaOpen( hostApi, parameters, streamDir, &pcm )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 1702
Code: Select all
Default capture device number: 15
Default playback device number: 15
Device ID: 0
Device name: HDA ATI SB: ALC1200 Analog (hw:0,0)
Host name: ALSA
Input channels: 2
Output channels: 8
Low Input Latency: 0.011610
Low Output Latency: 0.011610
High Input Latency: 0.046440
High Output Latency: 0.046440
Supported Rates:
44100
48000
96000
192000
Device ID: 1
Device name: HDA ATI SB: ALC1200 Digital (hw:0,1)
Host name: ALSA
Input channels: 0
Output channels: 2
Low Input Latency: -1.000000
High Input Latency: -1.000000
Supported Rates:
44100
48000
88200
96000
192000
Device ID: 2
Device name: HDA ATI SB: ALC1200 Alt Analog (hw:0,2)
Host name: ALSA
Input channels: 2
Output channels: 0
Low Output Latency: -1.000000
High Output Latency: -1.000000
Supported Rates:
Device ID: 3
Device name: Microsoft® LifeCam Cinema(TM): USB Audio (hw:1,0)
Host name: ALSA
Input channels: 1
Output channels: 0
Supported Rates:
Device ID: 4
Device name: sysdefault
Host name: ALSA
Input channels: 128
Output channels: 128
Low Input Latency: 0.042653
Low Output Latency: 0.042653
Supported Rates:
8000
9600
11025
16000
22050
32000
44100
48000
88200
176400
Device ID: 5
Device name: front
Host name: ALSA
Input channels: 0
Output channels: 8
Supported Rates:
44100
48000
96000
192000
Device ID: 6
Device name: surround40
Host name: ALSA
Input channels: 0
Output channels: 8
Supported Rates:
44100
48000
96000
192000
Device ID: 7
Device name: surround41
Host name: ALSA
Input channels: 0
Supported Rates:
44100
48000
96000
192000
Device ID: 8
Device name: surround50
Host name: ALSA
Input channels: 0
Supported Rates:
44100
48000
96000
192000
Device ID: 9
Device name: surround51
Host name: ALSA
Input channels: 0
Output channels: 8
Supported Rates:
44100
48000
96000
192000
Device ID: 10
Device name: surround71
Host name: ALSA
Input channels: 0
Output channels: 8
Supported Rates:
44100
48000
96000
192000
Device ID: 11
Device name: iec958
Host name: ALSA
Input channels: 0
Output channels: 2
Supported Rates:
44100
48000
88200
96000
192000
Device ID: 12
Device name: spdif
Host name: ALSA
Input channels: 0
Output channels: 2
Supported Rates:
44100
48000
88200
96000
192000
Device ID: 13
Device name: pulse
Host name: ALSA
Input channels: 32
Output channels: 32
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
176400
192000
Device ID: 14
Device name: dmix
Host name: ALSA
Input channels: 0
Output channels: 2
Low Output Latency: 0.042667
High Output Latency: 0.042667
Supported Rates:
48000
Device ID: 15
Device name: default
Host name: ALSA
Input channels: 32
Output channels: 32
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
176400
192000
Selected capture device: 15 - default
Selected playback device: 15 - default
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
176400
192000
Available mixers:
Available capture sources:
0 - Front Mic:0
1 - Rear Mic:0
2 - Line:0
3 - Front Mic:1
4 - Rear Mic:1
5 - Line:1
Available playback volumes:
0 - Master:0
1 - Headphone:0
2 - PCM:0
3 - Front:0
4 - Front Mic:0
5 - Front Mic Boost:0
6 - Surround:0
7 - Center:0
8 - LFE:0
9 - Side:0
10 - Line:0
11 - Beep:0
12 - Rear Mic:0
13 - Rear Mic Boost:0
Capture volume is native
Playback volume is native
What happens if you turn your computer off, disconnect the web cam, then with the web cam disconnected, restart the computer, then launch Audacity?defaria wrote:While this is happening the blue light on my web cam comes on for a while, blinks sometimes, stays solid for a while, etc.
Steve, unplugging my cam while machine is off then restarting solved this problem for me.
Thank you for that suggestion. Mine was at 4:20 to start up as well and was driving me batty.
Now this awesome program is usable again to me.
I run Linux Mint 17 RC Cinnamon 32bit.
Thanks again man.
Thanks again man.
- Quality Assurance
What is the make and model number of the web cam and does it have audio as well as video recording? Perhaps it is not Linux compatible or it requires Linux drivers to be installed?LeeMaiden wrote:Steve, unplugging my cam while machine is off then restarting solved this problem for me.
