Can I set a time limit on my recording?
gibby
Post by gibby » Sat May 10, 2014 5:53 am
Hello,
Let's say I want to hit record and leave the house for an afternoon. Is there any way to configure Audacity to stop recording after, say, half an hour? How about 1 hour? How about 5 minutes? In other words, can I set the time limit on which Audacity will record audio?
Oh, and I'm running Windows 7 with Audacity 2.0.5. I also have Audacity on a Mac OS X but I'm not sure the version, but I can easily upgrade to 2.0.5 (assuming it's available for Macs) so let's just say I have 2.0.5 for the Mac as well.
Thank you for any forthcoming help. ;)
Re: Can I set a time limit on my recording?
Post by kozikowski » Sat May 10, 2014 6:22 am
Transport > Timer Record.
You should be really careful and recheck your settings when you get ready to leave the house. All the settings, not just the ones you adjusted. I got in trouble once by rolling the date by accident and didn't catch it.
Post by steve » Sat May 10, 2014 11:26 am
Another way is:
1) Add a track (Tracks menu > Add New > Audio Track)
2) Select from the start of the track to the time that you want the recording to stop http://manual.audacityteam.org/o/man/au ... ction.html (using the Selection Toolbar is an easy and accurate method)
3) Ensure Transport > Overdub (on/off) is on (checked)
4) Press the Record button.
Recording will start in a new track, and stop at the end of the selection.
To remove the "dummy" track, click on the [X] in the top left corner of the track.
Reason: Added step to ensure overdub is on
gibby
Post by gibby » Wed May 14, 2014 3:19 am
Thanks everyone for your help.
