deformation in loopback recording [SOLVED]
Please state:
raphaelpoli
Post by raphaelpoli » Mon May 05, 2014 3:41 pm
When I record audio that is played by my computer thanks to pulseaudio volume control as indicaed in the wiki, there's a pitch of about 1,7 halftone lower. I corrected this at my ear, but I would like to understand how to evitate such deformation?
Re: deformation in loopback recording
Post by Gale Andrews » Mon May 05, 2014 4:53 pm
Try changing the Audacity project rate to 44100 Hz or 48000 Hz.
Try giving us some information to go on.
Version of Audacity?
Version of Linux?
Make and model number of computer?
Make and model number of sound device?
Exactly what you are recording, in what application?
raphaelpoli
Re: deformation in loopback recording [SOLVED]
Post by raphaelpoli » Tue May 06, 2014 10:13 am
Helo Gale Andrews, thank you for your reply that was effectively the problem of the rate, which was 48000 instead of 44100
yours,
Raphael
