convolution
This read-only archive contains discussions from the Adding Feature forum.
New feature request may be posted to the Adding Feature forum.
Technical support is available via the Help forum.
raphaelpoli
convolution
Post by raphaelpoli » Mon May 05, 2014 2:52 pm
Hello.
I've been using audacity a few times now. And I am aware there are a lot of things to add before this, but one very interresting function that I would love to be able to use is convolution. It is a function that allows to extract a tone from for example a short sample, and to blend it with a longer sound such as generated noise, in order to obtain a long sound with that precise tone.
hope you can guess how to do this!
yours,
Raphael
Re: convolution
Post by kozikowski » Mon May 05, 2014 7:15 pm
Most people want a convolver to suppress room echoes. It's the only tool that has any positive effect at all.
Re: convolution
Post by steve » Mon May 05, 2014 7:25 pm
Robert J. H.
Re: convolution
Post by Robert J. H. » Mon May 05, 2014 9:14 pm
A simple example (for the Nyquist Prompt):
Code: Select all
(setf i-r (abs-env (mult (noise) (pwe 0 1e-20 0.3 0.01 0.4 0.1 0.4))))
(convolve s i-r )
The impulse response is 0.4 s long, that's fairly long already.
Re: convolution
Post by Gale Andrews » Thu Jun 26, 2014 7:02 pm
I counted the vote and moved the topic here.
