My recording is skiping....:(
Help for Audacity on macOS.
kbsig175
Post by kbsig175 » Mon Apr 28, 2014 8:21 pm
Hi i could really use your help
I currently record from my 2 CDJ 900's and my DJM 900 mixer. I have the latest version of audacity 2.0.5. I use an external focusrite scarlett 2i4 sound card with my Mac Book pro. When I tried to record my track, the entire track was skiping and garbled. I tried unpluging the external sound card and used the computer sound card with not problems. I did just install the lastest OS mavericks update. Before I installed the Mac OS update, i had no problems with my external sound card.
Re: My recording is skiping....:(
Post by Gale Andrews » Mon Apr 28, 2014 11:24 pm
kbsig175 wrote:I did just install the lastest OS mavericks update. Before I installed the Mac OS update, i had no problems with my external sound card.
Then Mavericks is apparently the problem.
Have you tried http://forum.audacityteam.org/viewtopic ... 71#p233371 ?
[email protected]
Post by [email protected] » Thu May 01, 2014 4:43 pm
Hi there,
As Gale said, please try installing Class Compliant mode. To do this, please go to the following link, select the 2i2/2i4 and download the ClassCompliantMode.App.Zip file.
Then run/install the script and restart.
Let me know if this resolves the issue!
Best,
Miles
