Thanks to you, Gale.
Just to give some news.
Means-while, I have made a clean install of Mac OS 10.9.3, nothing really changes; and today added “Ram memory”. Mavericks jumps and runs now like a snow leopard, and Audacity works fine and smoothly, much better than before.
But the problem of importing big FLAC/OGG files persists.
I have no practice with the Terminal app; I’m not sure to understand your advice, (my english is too poor), and afraid to do a big mistake. So I have not tried it. It’s not really a problem, just a question about the strange behavior of Audacity 2.0.5 in importing this big hybrid Flac/OGG files.
What concernes VLC: since latest upgrading to 2.1.4 I have no more the possibility to transcode in WAV or uncompressed code; don’t know why. That’s what I did with VLC 2.0.8. Perhaps there is something to do in his mysterious advanced settings.
Thanks for your suggestions,
Regards
tobele
Audacity plante:import de fichier FLAC trop lourd?
Merci de noter que la plupart des membres de l'assistance d'Audacity ne parlent qu'anglais. Par conséquent, nous ne pouvons garantir une réponse aux questions en français.
Merci de noter que la plupart des membres de l'assistance d'Audacity ne parlent qu'anglais. Par conséquent, nous ne pouvons garantir une réponse aux questions en français.Si vous n'avez pas reçu de réponse et que vous pouvez parler anglais, merci de vous adresser au Forum anglais dans la section appropriée à votre système d'exploitation et à votre version d'Audacity.
- Quality Assurance
Re: Audacity plante:import de fichier FLAC trop lourd?
OK but I cannot make the crash happen on my Mac machine with a 1 GB "OGG file containing FLAC" written by VLC 2.1.4.tobele wrote:But the problem of importing big FLAC/OGG files persists.
In any case Audacity 2.0.6 when released will either update to FFmpeg 2.2.x or use FFmpeg indirectly through another API (GStreamer). So the behaviour may change in any case.
In VLC 2.1.4 on Mac I chose the "CD" format then chose WAV encapsulation and FLAC codec. At least I can do that if converting an existing file.tobele wrote:What concernes VLC: since latest upgrading to 2.1.4 I have no more the possibility to transcode in WAV or uncompressed code; don’t know why. That’s what I did with VLC 2.0.8. Perhaps there is something to do in his mysterious advanced settings.
