Menu bar
atomottokar
Menu bar
hello
when i load Audacity 2.0.5
it appear like without the top band [ see snapshot ]
only when i click the menus new does it come correctly .
i did try to re- install all the same .
do you have any light
thanks
thanks
- Quality Assurance
Re: vindow size
Do you mean "window size"?
Note that if you File > Close, Audacity reduces to a mimimal menu. You have to use File > New, Open... or Open Recent.
You did not attach a screenshot. Please see here for how to attach files: http://forum.audacityteam.org/viewtopic ... 49&t=64936 .
Installation does not change anything unless you initialise the audacity.cfg settings file. To do this, quit Audacity, open Finder, choose Go > Go to Folder and type:
Open audacity.cfg if it exists. Select all the text and delete it. Then type the following at the top of the file:
Save audacity.cfg and restart Audacity.
Code: Select all
~/Library/Application Support/audacity/
Code: Select all
NewPrefsInitialized=1Save audacity.cfg and restart Audacity.
atomottokar
Re: vindow size
hello
* snapshoot 10.16.01 PM
when i load no barre back
if i click new all ok the front picture
* snapshoot 10.17.57
i found this on the " show log "
i did not execute the manipulations you recommended . confirm if i schould execute thems
thanks a lot
thanks a lot
- Attachments
- Screen Shot 2014-04-26 at 10.16.01 PM.png (74.91 KiB) Viewed 1246 times
- Screen Shot 2014-04-26 at 10.17.57 PM.png (230.9 KiB) Viewed 1246 times
atomottokar
Re: vindow size
hello
audacity log snapshot
i solved the FF meg libraries error
but not the image error
thanks for your help
- Attachments
- Screen Shot 2014-04-27 at 7.25.48 PM.png (180.69 KiB) Viewed 1169 times
- Quality Assurance
Re: vindow size
If you want to use Mac you must accept that an application's menu bar is not part of the application.
There is a single system-wide menu bar that contains the menu for the application that currently has focus.
So if you create a second window for an application, the second window will not have an attached menu bar. If you only have one application window and drag it downwards or resize it, you will again see that the system menu bar is not attached to the application.
If the problem is something else then yes you should initialise audacity.cfg. Initialising audacity.cfg will not make the Mac's menu bar attach to the Audacity application.
Initialising audacity.cfg might solve a problem such as Audacity launching underneath the Mac's menu bar, so that you cannot access the Audacity window buttons.
atomottokar
Re: Menu bar
hello
ok so if i understand correctly i do have to reset audacity .cfg
schould i delete all the text except " NewPrefsInitialized=1 " close and re-start
or erase all and re-write " NewPrefsInitialized=1 " close and re-start
thanks to let me know
- Quality Assurance
Re: Menu bar
Perhaps. I do not understand the exact problem that you are complaining about.atomottokar wrote:ok so if i understand correctly i do have to reset audacity .cfg
It is safer to delete all the text then writeatomottokar wrote:schould i delete all the text except " NewPrefsInitialized=1 " close and re-start
Code: Select all
NewPrefsInitialized=1Gale
atomottokar
Re: Menu bar
when i click on " audacity cfg " folder
i got the image of another vst instrument witch is on my system and cannot delete the " Audacity cfg " text to write New..............
but i can delete the folder " audacity cfg "
what schould i do ?
what schould i do ?
- Attachments
- Screen Shot 2014-04-29 at 9.48.08 AM.png (272.32 KiB) Viewed 1112 times
- Quality Assurance
Re: Menu bar
Audacity > Quit Audacity if it is running, then delete the "audacity.cfg" file.atomottokar wrote:but i can delete the folder " audacity cfg "
Extract audacity.cfg from the attached zip by downloading the zip then double-clicking on it.
Copy the extracted audacity.cfg then paste it in to Macintosh HD/Users/<your user name>/Library/Application Support/audacity/ so that it replaces the "audacity.cfg" you deleted.
- Attachments
- audacity_cfg.zip
- (181 Bytes) Downloaded 42 times
atomottokar
Re: Menu bar
hello
weird look a the attachement , from your download i got NKP plugin and not Adacity.cfg snapshot
in my folder HD > library there is [ see snapshot ]
- Attachments
- Audacity .jpg (247.9 KiB) Viewed 1048 times
- Screen Shot 2014-04-29 at 9.49.42 PM.png (156.9 KiB) Viewed 1048 times
