LAME for Windows 8
bryanhiggs
LAME for Windows 8
Post by bryanhiggs » Fri Apr 25, 2014 10:25 pm
We have installed Audacity on a Windows 8 system, but we are having trouble finding a version of LAME that works on Windows 8.
We have searched for LAME for Windows 8, but unsuccessfully.
Can anyone help?
Thanks!
Re: LAME for Windows 8
Post by Gale Andrews » Sat Apr 26, 2014 2:05 am
Have you tried the relevant Frequently Asked Question: http://manual.audacityteam.org/o/man/fa ... .html#lame ?
bryanhiggs
Post by bryanhiggs » Sat Apr 26, 2014 2:25 am
Yes, I did look at that, and there is no mention of Windows 8 there.
Or are we supposed to conclude that it works by default, without specific mention?
I'd try it myself, but I'm trying to figure this out for a friend/colleague. She has the Windows 8 system; I don't, and I'm not at her place.
If someone can tell me whether the standard LAME is supposed to work on Windows 8, that would be help me avoid spinning my wheels!
Thanks!
Post by Gale Andrews » Sat Apr 26, 2014 3:15 am
If you want to download a LAME version that is suitable for Audacity I suggest you do that from http://lame.buanzo.org/#lamewindl as per the FAQ. Do not click on any advertisements on that site or you may harm your computer. That LAME version is suitable for Windows 2000 through to Windows 8.1 (there are no operating system requirements other than that).
DarkBlood202
I can't Download LAME For Audacity
Post by DarkBlood202 » Sat May 10, 2014 5:48 am
Ok, This is my problem. Today i was working in an audio track, so when i finished i Wanted to export as a mp3 file. But when i try a pop-up from audacity says me: "Audacity needs the file lame_enc.dll" So i click in the button to download it. But when i clicked the button and it sends me to the Audacity "support" page. In that page, the link "lame1.buanzo.com.ar" is not avaliable!
Please, If you can solve this problem :/ or, by the way, there's another page to download "LAME" for Windows?
PD: I'm using Audacity 2.0.5 in Windows 8
Post by steve » Sat May 10, 2014 11:30 am
Try the instructions here: http://manual.audacityteam.org/o/man/fa ... .html#lame
I've just checked the links. The download site is a bit slow at the moment but it is working.
