vinyl effect plug-ins
atomottokar
mac book pro 10.8.5
hello
there was a " vinyl " plugin where it is and may i install it with Adcty 2.0.5
thanks to let me know
hello
Reason: More descriptive topic title
- Quality Assurance
Re: vinyl
You can use the "VyNil" effect ( http://plugin.org.uk/ladspa-swh/docs/la ... h_sEc2.109 ) in the SWH LADSPA plug-ins you already have.atomottokar wrote:mac book pro 10.8.5
See here for how to install the SWH LADSPA plug-ins: http://forum.audacityteam.org/viewtopic ... 04#p237404 .
Or use iZotope Vinyl VST from http://downloads.izotope.com/product_do ... v1_73c.dmg . Please see here for how to install VST plug-ins: http://manual.audacityteam.org/o/man/fa ... st_install .
atomottokar
Re: vinyl
hello
i changed systems so !
i tried to install " izotope vinyl " programmations too complex
so i trashed all but the name izotpe vinyl is still in the menus effect
and i cannot get it out .
thanks for your help
- Quality Assurance
Re: vinyl
All you should need to do is Audacity > Quit Audacity then launch Audacity again.atomottokar wrote:i tried to install " izotope vinyl " programmations too complex
atomottokar
Re: vinyl
hello
no that is the problem it still there in alphabet letter on the menus effect !
- Quality Assurance
Re: vinyl
What happens if you click that Effect menu item for iZotope Vinyl? If the effect appears then you have not got rid of it.atomottokar wrote:no that is the problem it still there in alphabet letter on the menus effect!
On Mac, Audacity looks for VST plug-ins in the "Plugins" folder in the Audacity installation folder, and in Users/<your user name>/Library/Audio/Plug-Ins/VST and /Library/Audio/Plug-Ins/VST .
If preferred, another solution is to open Audacity > Preferences. In the "Effects" section, put a checkmark (tick) in "Rescan VST effects...", click OK and restart Audacity. You will see the "Install VST Effects" dialogue. If you see iZotope Vinyl in the list in that dialogue, remove the checkmark from it then Audacity will not load it.
atomottokar
Re: vinyl effect plug-ins
hello
no the VST folder is empty !
so re-scan will do nothing .
but still izotope is still in the effect , weird !
i sended a support message to Izitope , maybe there is an un-install procedure .
- Quality Assurance
There are two folders called "VST" where Audacity looks for VST plug-ins, as I described.atomottokar wrote:no the VST folder is empty !
You should rescan, I think.atomottokar wrote:so re-scan will do nothing .
If the rescan finds iZotope in the "Install VST Effects" dialogue, uncheck iZotope, then it will not appear in Audacity.
atomottokar
hello
SHAME ON ME i did the manipulations of the first part of your message
" in Users/<your user name>/Library/Audio/Plug-Ins/VST
and /Library/Audio/Plug-Ins/VST "
but realised just now that you wrote AND /Library/Audio/Plug-Ins/VST "
just did it and problem resolved !
well ! still shame on me it will have been more obvious for me if the second part was
and HD /Library/Audio/Plug-Ins/VST "
since i did not know thoses were thoses too in the HD !
a truth thanks for your help and patience !
- Quality Assurance
Probably I should have made the locations into a list.atomottokar wrote:it will have been more obvious for me if the second part was and HD /Library/Audio/Plug-Ins/VST since i did not know thoses were thoses too in the HD !
Mac has two distinct "Library" folders, the system library (Macintosh HD/Library/) and the user's Library (Macintosh HD/Users/<user name>/Library/).
The system library is hidden on most versions of OS X as far as I know, and the user's library is hidden from OS X 10.7 (Lion) onwards. So you need to access those locations using Go > Go to Folder in Finder, or enable showing hidden files and folders in the Terminal ( http://www.mikesel.info/show-hidden-fil ... 10-7-lion/ ).
