only line entry on with US-122
banyeli
Re: only line entry on with US-122
Post by banyeli » Fri Apr 25, 2014 4:12 pm
argh, it just made the same on qbase... so not an audacity pb... maybe with win 7?
thx for beeing there any way!!!
Ban
Post by steve » Fri Apr 25, 2014 4:49 pm
Check that you have the most recent drivers installed: http://tascam.com/product/us-122l/downloads/
(read the "release note" document before installing the drivers)
banyeli
Post by banyeli » Fri Apr 25, 2014 5:50 pm
that's what I've done (I tried the 2 different drivers proposed on the site)
I suspect now maybe a electrical problem on the usb plug...
I'll come back here if I find some kind of Windows7 or audacity problem
thx a lot!
Post by steve » Fri Apr 25, 2014 6:58 pm
banyeli wrote:I'll come back here if I find some kind of Windows7 or audacity problem
Please let us know if you discover the cause and/or solution, whatever it happens to be. It could help other Audacity users if they encounter the same problem.
Good luck.
Post by Gale Andrews » Fri Apr 25, 2014 8:11 pm
Also make sure you connect to an empty USB hub on the computer.
Windows 7 has sample rate and sample format settings. When using external devices you need to be sure Windows settings don't conflict with Audacity settings. Try Host: Windows DirectSound in Device Toolbar . Set Project Rate bottom left to 48000 Hz. Choose Edit > Preferences, choose "Quality" and set "Default Sample Format" to 24-bit.
Then right-click over the speaker icon by the system clock, and choose "Recording Devices". Right-click over the Tascam and choose "Properties". Then click the "Advanced" tab and put a checkmark (tick) in both Exclusive Mode boxes. Click OK and OK and restart Audacity. Then even if "Default Format" on that "Advanced" tab conflicts with your Audacity settings, Audacity should ignore the Windows Default Format and request the rate and bit depth directly from the device.
