Sync Drift from different Zoom Recorders
Pianobyme
Post by Pianobyme » Fri Apr 25, 2014 2:27 am
I'm using audacity 2.0.5 and am helping with a student video interview project.
One of my lav mics was acting funny on the morning of the interview so I decided to use my trusty Zoom H2, which got great audio from the subject (no budget and all). The interviewer used the other lav hooked up to a Zoom R24. I was intending to use the R24 for both lavs, but with the primary one not working, I just kept the interview setup as he was and setup the zoom H2 for a quick fix.
I imported both tracks into Audacity and synced them at the beginning, and by minute 30 there is significant drift, and I can't figure out how exactly to fix them. I know that this sometimes has to do with the recording rates being off, but I checked both of the devices were recording at 44.1/16 bit, and the audacity project is working in 44.1 as well. I'm certainly an amateur so any suggestions as to where I should look for a fix would be greatly appreciated. Cheers.
Re: Sync Drift from different Zoom Recorders
Post by kozikowski » Fri Apr 25, 2014 3:29 am
They were both running at 44100 according to each one's own individual internal clock electronics — the electronics that have manufacturer's tolerances. So now you know why that person (usually Camera Assistant) goes out in front of the camera at the beginning of a film shoot and loudly says,"Camera Mark!" and slams that clapboard shut. The slam is for the sound people and the picture of the closure is for the camera.
In your case you're going to also need an end mark. Given that nobody went out at the end of the shot with the clapboard upside down (End Mark), you're going to need to find a sync point on your own and use Effect > Change Speed to match the two clips up. Hope that someone dropped a pencil or something for the sync mark. Trying to do it with lip sync is rough.
There is a formula for starting with your known time offset and deriving the weird numbers that Effect > Change Speed needs. I need to look that one up.
Post by kozikowski » Fri Apr 25, 2014 3:32 am
If you have to do this again, as you noticed, separate sound can work perfectly well and is generally preferred, somebody needs to appear on camera and clap at the beginning and the end — just like the big kids.
Post by kozikowski » Fri Apr 25, 2014 3:34 am
Post by kozikowski » Fri Apr 25, 2014 3:37 am
A note. You don't have to find a sync point at the very end of the shoot. It's best if you do that, but anywhere in the end quarter of the shoot should be close enough, particularly if it's human lips. Koz
Post by steve » Mon May 05, 2014 1:59 am
There is a plug-in that allows you to stretch the selected audio to a precise length: http://forum.audacityteam.org/viewtopic ... 49#p172749
(this may be easier than trying to calculate the necessary percentage change).
Post by kozikowski » Mon May 05, 2014 3:02 am
Remember, none of us are horrified you're doing this. You can frequently get much better Separate Sound than you can with camera built-in sound. As long as you know there might be a sync issue, you can be ready for it (it's the surprises that kill). You might even discover the correction is always the same number (as long as you don't change hardware) and you barely have to think about it.
Attached is a Nagra III that the movie people used for years. It's claim to fame it stunningly accurate motors designed to keep up with the movie camera motors. That's why most times we only need the clap at the front. The two will run independently of each other in frame sync for hours.
Screen shot 2014-05-04 at 7.58.04 PM.png (238.44 KiB) Viewed 1408 times
brianejsmith
Post by brianejsmith » Wed May 07, 2014 3:49 pm
Hi Koz
Why don't all vision and sound recording devices have a button and circuit to synch the two inputs?
A button that when pressed set a timer and made an external noise at exactly the same time would do the job brilliantly.
The same circuit could be used on all devices making it really cheap. The frequency of the noise it makes could even be outside the normal hearing range and detectable only by the device (and thus making it immune to interference from random extraneous noises) meaning the operator could resynch at will whenever necessary during a continuous recording of any significant length.
I've got a Zoom Q2 HD which for the few pounds it cost me does a brilliant job of filming and recording; it just doesn't get them together making it pretty useless at anything.
Post by steve » Wed May 07, 2014 5:25 pm
That's what a "word clock" is for: http://en.wikipedia.org/wiki/Word_clock
brianejsmith
Post by brianejsmith » Wed May 07, 2014 5:35 pm
Hi Steve
I don't think it's quite what I had in mind. It seems to be a means of keeping devices on a network in sync a bit like GPS does.
I was thinking of a very simple, massively common (and therefore cheap as chips, ha ha) solid state device that would be completely self-contained, requiring no contact with the outside world or external services of any kind, that would simply make a timing mark on a video recording (a flash perhaps?) and at the same generate an audio noise which would be captured by the device's external microphone.
Software in the device would use the measured timing difference (the lag or latency) to automatically correct the recording with no further human intervention, editing etc, required.
