i'm using audacity as a sort of DAW.
can i do automation with audacity, like changing cutoff frequency over time?
thanks
automation in audacity
- Quality Assurance
Re: automation in audacity
It isn't really a DAW in the same way as full DAW's.046oh wrote:i'm using audacity as a sort of DAW.
If you are asking for real-time effects, no.046oh wrote:can i do automation with audacity, like changing cutoff frequency over time?
You can make duplicate tracks with different cutoffs, then turn on Envelope Tool . Then you can make a mix that has different proportions of the tracks.
