Bass Boost effect
This board is ONLY for general feedback and discussion about Audacity 2.X.
If you require help, or think you have found a "bug", please post on the forum board relevant to your operating system.
Bass Boost effect
Hello
I have been user of audacity software and I want to thank the team for creating such a wonderful tool.
I downloaded the new version of the software but find that in "effects" column, the "bass boost" plug in has been replaced by "bass & treble" plug in.
I would request the team to kindly either bring back the old plug-in or add that in the list as i found that was the most useful plug in for me as could actually treat bass frequencies individually which was a boon. The new plug-in is totally of no use, at least for me.
Hoping needful would be addressed.
Much thanks
Much thanks
Re: Bass Boost effect
Bass Boost was upgraded to "Bass and Treble" for several reasons, including; a bug that could cause irreparable clipping distortion of the processed audio, some users wanted to be able to reduce the bass (not possible in the old effect), some users wanted to boost the treble (not possible in the old effect), some users wanted to reduce the treble (not possible in the old effect).
However, it is recognised that some users would prefer the old effect, so there is now an optional plug-in version of it available from here: http://wiki.audacityteam.org/wiki/Nyqui ... Bass_Boost
Installation instructions are here: http://wiki.audacityteam.org/wiki/Downl ... g_Plug-ins
Can I ask which feature of the old Bass Boost effect you miss? Is it primarily the "Frequency" option?
As well as the user selectable frequency, the old Bass Boost effect also had a much "steeper" filter slope.
How could the current Bass and Treble effect be modified so as to suit you?
Hi
Thank you for the prompt response.
When you apply uniform gain or amplify the bass frequencies the higher frequencies in 150-200 Hz range usually go so deep that they spoil the whole song with extreme humming and over powering all else in the song. I prefer to reduce those and increase frequencies in the range of 40-60 Hz which give a much deeper,crisper yet non irritable bass.
This allows to first play on equalization of individual frequencies and later play up the lower bass frequencies thereby reducing the need to apply uniform amplification.
The current version in some cases either completely reduces the amplitude or uniformly increases which does not provide the intended result.
Also I noticed whenever I am using Multiband EQ, the software becomes unstable and crashes. It has never happened before with Audacity so maybe if somebody could address that.
]Can I ask which feature of the old Bass Boost effect you miss? Is it primarily the "Frequency" option?
I would prefer if there were separate plug-ins for both bass and treble with option to focus on frequencies which can be boosted as per individual taste like it was earlier.How could the current Bass and Treble effect be modified so as to suit you?
There was another suggestion I wanted to make thus using separate post.
I installed additional plug-ins list which makes the list extensive. When you are down browsing, its not a problem but if you have to go up the list and click on UP arrow, many times it keeps minimizing or maximizing the window cause its next to top window bar.
I would suggest there be a scroll feature or a search function in effects column so that desired plug-in can be accessed directly instead of every time going up and down.
Thanks
Thanks
Do you mean the "Equalization" effect (http://manual.audacityteam.org/o/man/equalization.html)?lodaxstax wrote:Also I noticed whenever I am using Multiband EQ, the software becomes unstable and crashes.
I presume that you are using Audacity 2.0.5. Is that correct? (look in "Help > About Audacity" to check the version number).
It would be best if you start a new topic for that, so that it gets the attention it deserves,lodaxstax wrote:There was another suggestion I wanted to make thus using separate post.
As you are suggesting a new feature I'd suggest that you post it in this part of the forum: http://forum.audacityteam.org/viewforum.php?f=20
steve wrote:Do you mean the "Equalization" effect (http://manual.audacityteam.org/o/man/equalization.html)?lodaxstax wrote:Also I noticed whenever I am using Multiband EQ, the software becomes unstable and crashes.
Yes I m using Audacity 2.0.5
This is the plug in I am talking about.keeps crashing the software.Multiband EQ
(multibandeq.ny) View | Download
Author: David R.Sky
Select total number of bands (T, from 2 to 30), band number (1 to 30, depending on how many total bands T you chose), and apply gain (-24 to +24 db). Determines width of band depending on total band number T you chose.
OK, thanks, I'll take a look.lodaxstax wrote:This is the plug in I am talking about.keeps crashing the software.
I think that the best tool for you would be the Equalization effect. In the "Draw Curves" mode it provides very powerful and detailed control of the frequency content. (http://manual.audacityteam.org/o/man/equalization.html)lodaxstax wrote:When you apply uniform gain or amplify the bass frequencies the higher frequencies in 150-200 Hz range usually go so deep that they spoil the whole song with extreme humming and over powering all else in the song. I prefer to reduce those and increase frequencies in the range of 40-60 Hz which give a much deeper,crisper yet non irritable bass.
I've had a look at the code and tested the effect.lodaxstax wrote:Also I noticed whenever I am using Multiband EQ, the software becomes unstable and crashes. It has never happened before with Audacity so maybe if somebody could address that.
There are a couple of "peculiarities" in the code, but I don't see anything to account for crashing. Also I've not been able to make it crash.
Are there specific steps that I should try that will reliably produce a crash?
I don't know that. but I have observed it crashing when I am using the above plug-in. I keep shuffling between equalization and multiband EQ. the software shows error and closes when I am working on the latter. It has never occurred before. Yes earlier I was using earlier version of Audacity and didn't have Multiband EQ so I am guessing it's got to do with it.steve wrote:I've had a look at the code and tested the effect.lodaxstax wrote:Also I noticed whenever I am using Multiband EQ, the software becomes unstable and crashes. It has never happened before with Audacity so maybe if somebody could address that.
