upper/lower case flaw?
This section is now closed
almapercus
Post by almapercus » Sun Dec 21, 2008 6:59 pm
Here's a problem I've encounter with an aiff file made with audacity.
As specified by the programmer, the file wasn't working properly because:
The file compression (or type in this case) written is 'FL32' and it should be lowercase 'fl32'.
Robert
Re: upper/lower case flaw?
Post by steve » Mon Dec 22, 2008 5:33 pm
almapercus wrote:the file wasn't working properly...
The file wasn't working properly in what?
Exactly what Export options did you select?
almapercus
Post by almapercus » Tue Dec 23, 2008 2:47 am
I was importing an audio file in Metro.
