Recommendations for a studio mic for vocals?
Did you buy a new mixer? Do you need advice? Post here.
Re: Recommendations for a studio mic for vocals?
Post by kozikowski » Fri May 16, 2014 12:36 pm
The only thing I can think of that I would change at this point is that I wish I could set it to some kind of mode that would output a separate file for each time I pressed the record button, since I am primarily using it for video production.
That's the kind of personal user experience I was after. Does it allow you to set a marker every time you do that so it's easier to find the cut points later?
Post by kozikowski » Fri May 16, 2014 12:41 pm
If you use a clapboard for your recordings, that will produce an easily recognizable spike in the sound.
http://www.bhphotovideo.com/bnh/control ... &A=details
"Camera Mark!" [bang]
You can get them a lot cheaper. If you routinely use separate sound, your editor will thank you.
