Find out what effects have been applied
in3D
Post by in3D » Thu Apr 03, 2014 3:40 am
I'm trying to figure out what effects have been applied to the second song below, with little success besides that it might be compression or purposeful clipping. How would I find out *exactly* what they are?
https://www.youtube.com/watch?v=V8VvkrYjWMY
https://www.youtube.com/watch?v=PX7zPlQjAr8
Re: Find out what effects have been applied
Post by kozikowski » Thu Apr 03, 2014 5:14 pm
Contact the production agency or the artist. There's no way to work it back from the finished song.
in3D
Post by in3D » Thu Apr 03, 2014 5:43 pm
That's unfortunate. The original poster is gone...
Post by kozikowski » Thu Apr 03, 2014 6:14 pm
You can get something similar with multiple passes through Effect > Leveler at its highest setting. Intentionally creating clipping distortion in Audacity is a little rough because it was designed internally not to overload.
Or try Effect > Simple Distortion.
Post by steve » Thu Apr 03, 2014 7:01 pm
kozikowski wrote:Or try Effect > Simple Distortion
We don't currently ship a distortion effect, that is a feature request.
Please add your vote here if you think that Audacity should include (at least) one distortion effect. http://forum.audacityteam.org/viewtopic ... 33#p241233
in3D
Post by in3D » Thu Apr 03, 2014 9:03 pm
Yes, leveler gets a similar effect, but a frequency analysis shows that there's something else in a higher frequency that I can't seem to replicate.
DVDdoug
Forum Crew
Post by DVDdoug » Thu Apr 03, 2014 10:07 pm
You can get clipping by using Amplify to push the peaks above 0dB. (Click the Allow Clipping check box.) Then export to 16-bit WAV. The WAV file will be clipped at 0dB. (Audacity will happily go above 0dB internally without clipping, so it's not clipped 'till you export to an integer WAV format.)
The higher you go the more distortion you'll get. You may not hear the distortion with a couple dB of clipping, but with 20 dB of clipping it should sound absolutely terrible! :D
Clipping will generate higher frequency harmonics (harmonic distortion) but I don't know if you'll get the same high frequencies as your example.
Effect - Hard Limiter can also introduce clipping (at whatever level you set). If you use the limiter, you may want to Amplify afterwards to re-boost the volume.
Post by steve » Thu Apr 03, 2014 11:57 pm
A little bit of code that can be run in the Nyquist Prompt (http://manual.audacityteam.org/o/man/ny ... rompt.html) to add distortion:
Code: Select all
(setq amount 4) ; bigger number for more distortion
(defun hardclip (s amount)
  (setq amount (db-to-linear (- amount)))
  (mult (/ 0.99 amount)(clip s amount)))
(multichan-expand #'hardclip s amount)
Trebor
Post by Trebor » Fri Apr 04, 2014 6:52 am
in3D wrote:I'm trying to figure out what effects have been applied to the second song below, with little success besides that it might be compression or purposeful clipping. How would I find out *exactly* what they are?
The second YouTube sounds hideous , but if you want to replicate it maybe try decimation , (which does add high frequencies) ...
Music box , before-after ''smooth decimator''.wav
(1021.31 KiB) Downloaded 40 times
http://plugin.org.uk/ladspa-swh/docs/la ... th_sEc2.99
Post by Gale Andrews » Fri Apr 04, 2014 7:04 pm
If you want that, go here http://manual.audacityteam.org/o/man/ef ... PA_Effects and use the links for "Additional LADSPA plug-ins can be downloaded".
