Since GSnap renders an undesirable phaser-like tone to the human voice, I want to try the alternative of AutoTalent by Tom Baran. I downloaded AutoTalent from Oli Larkin's site and extracted the files into Audacity's Plug-Ins sub-directory, deleting the "_MACOSX" folder and keeping only "autotalent.dll" and the "src" folder. After launching Audacity, importing an audio file, highlighting a section of the file, I did not see AutoTalent in the Effects list.
If anyone has managed to get AutoTalent to work in Audacity (running Win 7), maybe they can share the trick.
Anybody able to make "AutoTalent" appear?
Reason: More accurate title
Re: Anybody able to make "AutoTalent" work?
The website says:
That means you have to download the source code and compile it for Windows. That's something normally done by a programmer... I've done some programming before, but I don't know how to compile an LADSPA program. You don't have to be a programmer to do it, but installing, configuring and learning to use a particular complier can be a trying experience.Will Autotalent work on my computer?
Autotalent is an open-source LADSPA plugin and should in theory work on Linux, Mac or Windows if you compile it for those platforms, although Autotalent v0.2 has only been tested on 64-bit Linux. (Autotalent v0.1 had been tested on 32-bit Linux.)
- Quality Assurance
Given Djard has "autotalent.dll" and not compiled it, I think he or she probably has the precompiled VST port. If not, Djard can get it from http://www.olilarkin.co.uk/downloads/ol ... -2_win.zip or http://www.vst4free.com/free_vst.php?pl ... ent&id=842 .DVDdoug wrote:you have to download the source code and compile it for Windows.
Assuming you have the VST version of Autotalent and are using the current Audacity 2.0.5 (see Help > About Audacity... for the version you have) then you will need to do the following. Choose Edit > Preferences, choose "Effects" on the left, check (tick) the box "Rescan VST effects next time Audacity is started", click OK, then restart Audacity. This procedure is explained in the FAQ's: http://manual.audacityteam.org/o/man/fa ... st_install .Djard wrote:I downloaded AutoTalent from Oli Larkin's site and extracted the files into Audacity's Plug-Ins sub-directory, deleting the "_MACOSX" folder and keeping only "autotalent.dll" and the "src" folder. After launching Audacity, importing an audio file, highlighting a section of the file, I did not see AutoTalent in the Effects list.
For Autotalent documentation see http://tombaran.info/autotalent.html and http://tombaran.info/autotalent-0.2_refcard.pdf .
That did the trick. I did everything correctly but forgot to rescan VST effects in Preferences. AutoTune doesn't seem very accommodating to the musician, but maybe I need to play with it some more. I also noticed there are other pitch correction apps available that might also be open source, like VocPro, Vocalist and KeroVee. Thanks for the kind help.
- Quality Assurance
Re: Anybody able to make "AutoTalent" appear?
As far as I can tell, Vocalist Live and VocPro are hardware.Djard wrote:I also noticed there are other pitch correction apps available that might also be open source, like VocPro, Vocalist and KeroVee.
KeroVee is not open source. It has the usual issues when used in Audacity that the tuned note will be time-shifted, and MIDI tuning will not work.
