Any better pitch correction tool for Audacity?
Djard
Post by Djard » Wed Mar 26, 2014 8:54 pm
Like the Pitch Shift tool that causes some audio drift, GSnap unacceptably stretches the audio, requiring correction of the timing in the waveform after applying the effect. I can live with this defect as it's correctable but wonder if there is some other pitch correction tool plugin for Audacity that does not mess up the timing. Another freeware option would be nice.
Re: Any better pitch correction tool for Audacity?
Post by steve » Wed Mar 26, 2014 10:07 pm
For manual pitch correction (where you decide how much and which direction to change the pitch), try the Sliding Time Stretch / Pitch Shift effect: http://manual.audacityteam.org/o/man/sl ... shift.html
For automatic pitch correction (like AutoTune) you will probably need to spend money. There are a couple of free ones (such as GSnap and AutoTalent) but they're a bit limited.
DVDdoug
Forum Crew
Post by DVDdoug » Wed Mar 26, 2014 11:49 pm
Note that neither Auto-Tune nor Melodyne officially support Audacity, so you might also have to spend money on a host application.
Djard
Post by Djard » Fri Mar 28, 2014 3:25 am
Thanks... that helped me a lot. I'll try AutoTalent. If that renders an unprofessional sound, I'll just have to spend some $.
In addition to causing audio drift, GSnap adds a phaser-like tone to a human voice that might be OK for hard rock, but it's unacceptable in ballads and most pop (juz my 'pinion).
Djard
Post by Djard » Fri Mar 28, 2014 3:27 am
Thanks. I'm a guitarist, but I do have a keyboard and will give that option a try.
Post by Gale Andrews » Fri Mar 28, 2014 10:25 pm
Djard wrote:In addition to causing audio drift, GSnap...
Used in Audacity, GSnap inserts 10 milliseconds of silent audio at the start of the processed selection, and 10 milliseconds of the selection are removed at the end. This is an Audacity limitation because it does not compensate for plug-ins that buffer audio in order to provide "look ahead".
