I tried this but had problems exporting back to the original wav file. Perhaps this is because it was open and presumably locked by Audacity?stevethefiddle wrote:You must EXPORT audio files from Audacity (WAV, or any other supported audio format).
I wonder if there is a way to automate the process of loading a WAV file into an Audacity project , detecting the save project event and then running something to extract the saved file from the project copy and back to the orignal file. Given that the source code is open sourcish, has anyone already done this?
This brings me to another question. Reaper, a low cost DAW package depends upon and external audio editor to handle direct waveform manipulation. Has anyone figured out how to use Audacity to handle this job?
My hovercraft is full of eels.stevethefiddle wrote:Try FlexiMusic Kids Composer - it's not free ($15) but they claim that it is "a fun, easy way for kids to learn the basics of music-making and recording." ...snip ... They also do a more advanced version called "FlexiMusic Wave Editor" for $20 (7 Day free trial available), but that may also be too difficult for your needs.
