stretching the end of an audio
046oh
Post by 046oh » Fri Mar 14, 2014 1:37 am
can i select a portion of audio and stretch it in order to extend the tone?
Re: stretching the end of an audio
Post by kozikowski » Fri Mar 14, 2014 5:28 am
Sure. If the song ends with one single long note, zoom in, drag-select a portion of the last note, copy and paste it into the song's end again and again. It will keep making that one long note longer and longer. Doesn't have to be at the end, either. You can paste just before the end and the new note will fit in with the others.
Let us know if you get a tick or pop at the paste points.
Post by Gale Andrews » Fri Mar 14, 2014 7:23 pm
I would be lazy and use Effect > Repeat... . It shows you the new length of the selection after the repeats.
Post by steve » Sat Mar 15, 2014 11:24 am
If you're wanting to stretch the last note of a recording, try the "Sliding Time Scale / Pitch Shift" effect: http://manual.audacityteam.org/o/man/ef ... html#slide
Post by Gale Andrews » Sat Mar 15, 2014 5:08 pm
steve wrote:If you're wanting to stretch the last note of a recording, try the "Sliding Time Scale / Pitch Shift" effect: http://manual.audacityteam.org/o/man/ef ... html#slide
For most "real music" that is that I would suggest - a note at the end of a song tends to change over time, so pastes or repeats rarely sound right.
However I thought we might be talking about Generate > Tone, in which case there may be no need to use time stretching, which is always slightly lossy.
Trebor
Post by Trebor » Sat Mar 15, 2014 9:04 pm
046oh wrote:can i select a portion of audio and stretch it in order to extend the tone?
Clue in the title : paulstretch ... http://manual.audacityteam.org/o/man/paulstretch.html
You would need to create a mix of the original and the stretched version ... http://forum.audacityteam.org/viewtopic ... 614#p99614
Post by steve » Sun Mar 16, 2014 1:35 am
Trebor wrote:Clue in the title : paulstretch ... http://manual.audacityteam.org/o/man/paulstretch.html
One of the proposed names for that effect was "Extreme Stretch". That would have been appropriate.
046oh
Post by 046oh » Mon Mar 17, 2014 2:04 am
thank you!
i tried the looping, but it produced clicks, so i manually did some crossfading.
i tried paulstretch for another sample, and it worked quite well :)
