dead space at end of imported wavs
This section is now closed
milsam
Post by milsam » Wed Dec 17, 2008 3:48 pm
I'm using 2.1.6 on powerbook (having lost about 30 hours of work on audacity 3 last night). When I import wavs, they all have extra dead space at the end. It's a lighter shade of grey than where the file actually exists, and has no wav form in it. The cursor stops when it gets to it. However, I cannot delete it. When I copy the part of the wav I want and paste it in a new audacity project, the dead space comes with it. When I export the selection I want as a wav, the dead space comes with it (or I end up with silence instead). The wavs work and do not have this dead space when I play them in itunes. I cannot complete--or even really restart--the projects that I lost last night.
If I can't use audacity (as I'm rapidly losing hope), any other suggestions of a program I could use?
Re: dead space at end of imported wavs
Post by kozikowski » Wed Dec 17, 2008 4:28 pm
You might have the wrong Audacity and that's why it doesn't work right. This is the information I need from you and where to find it. This example is the machine I'm typing on now. There is no Audacity 2.1.6
I have a question about Audacity 1.3.5 [1] running on my 1.83 GHz Intel Core Duo [2] Mac Mini [3] under Mac OS-X 10.4.11 [2].
[1] Launch Audacity > Audacity > About.
---or sometimes---
[1] Launch Audacity > Help > About Audacity.
[2] Apple > About This Mac.
[3] Apple > About This Mac > More Info > Hardware > Model Name.
milsam
Post by milsam » Wed Dec 17, 2008 4:35 pm
got the number reversed...audacity 1.2.6 on a 867 MGz PowerPC G4 running OS X 10.4.11
Post by steve » Wed Dec 17, 2008 5:06 pm
milsam wrote:When I import wavs, they all have extra dead space at the end. It's a lighter shade of grey than where the file actually exists, and has no wav form in it. The cursor stops when it gets to it.
Could you post a screenshot.
milsam
Post by milsam » Wed Dec 17, 2008 5:27 pm
it's attached
[The extension tiff has been deactivated and can no longer be displayed.]
Post by steve » Wed Dec 17, 2008 5:40 pm
I have marked on the image the end of the track. The area to the right of this is nothing - it does not contain any audio data. This is normal. (you may need to scroll the image to the right).
Also, a quick tip - when posting images, use .jpg, .gif or .png format. A lot of browsers do not support .tiff images.
milsam
Post by milsam » Wed Dec 17, 2008 5:45 pm
Yes, I know it looks like that, but I can't paste other audio over it, nor can I hear audio in other tracks beneath it when I add them. They'll play when they're under the top audio track, but not under the blank space.
Post by steve » Wed Dec 17, 2008 6:05 pm
I can't remember exactly how Audacity 1.2.6 handles those situations, but if you use Audacity 1.3.x it should play audio clips wherever they are placed on the time line.
Note that you can only paste audio of a similar type into a track - you cannot paste stereo audio into a mono track, or the other way round.
