Audacity Sluggish and Often "Not Responding"
AudacityAholic
Re: Audacity Sluggish and Often "Not Responding"
your probably have too many programs running in the background while your running audacity...this program does require alot of ram when running effect especially if you are running an effect over the entire project...you can hit ctr alt del and go into task manager....kill some apps and processes you dont really need running
- Quality Assurance
That is only true for Nyquist effects (and it affects some of those more than others). It is not a serious problem for built-in effects.AudacityAholic wrote:this program does require alot of ram when running effect especially if you are running an effect over the entire project
Waiting for the waveform to redraw after running any effect on a long project is an issue.
An effect may well use up a significant proportion of CPU.
