Hi - I'm new to Audacity use. When I press record to record a second audio, the first audio plays-back. I'm practicing the programme to become
familiar. I'm trying to record a second audio in order to tag it to the first. (Then I aim to bolt it to the first recording to make one project.) Hope I've made it clear to the forum! Thanks in advance for guidance.
Repeating-audio project playback
sparksfingers
Re: Repeating-audio project playback
You can make the original audio stop playing with a setting.
Audacity > Edit > Preferences > Recording > [_] Overdub (de-select).
You can make your own live audio stop playing with another setting.
Audacity > Edit > Preferences > Recording > [_] Playthrough (de-select).
sparksfingers
My grateful thanks to Koz - your guidance did the trick
