How to change key of a song?
serpentyne
Hi - I'm a newbie here, so forgive me if I'm clueless about a lot of things. I want to change the key of an entire song from, say, F-key to D-key. How am I supposed to go about doing that?
stearman65
Re: How to change key of a song?
Hi
Hilight your song, click effect, scroll down to change pitch and select the key you want. You may have to juggle other settings after you change.
Stearman65
Stearman65
You should be aware that the further you "de-tune" the song, the worse the sound quality will be.
If it doesn't matter about the tempo of the song, then the "Change Speed" effect gives better sound quality (but both tempo and pitch will change together - just like playing a record at the wrong speed).
