Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at
https://www.audacityteam.org/download/.
The old forums for those versions are now closed, but you can still read the archives of the
1.2.x and
1.3.x forums.
- Quality Assurance
Post
by Gale Andrews » Tue Mar 08, 2016 1:52 pm
hans-jürgen wrote:Just adding a current info referring to Audacity 2.1.2 and v3.232 of Anwida Soft DX Reverb Light: if you have copied or moved the downloaded .dll to the correct plugins subfolder of Audacity, you have to activate Anwida in the plugins manager (as it is listed as "new" there which means it will not show in the effects list), and then you can find it as "L1V" in the list of available external effects, not as "Anwida Soft DX Reverb Light". This is of course a bug, because
L1V would be their limiter/maximizer plug-in, not the reverb, see also their
download page.
It's a "bug" in the plugin, not Audacity. Anwida named the DXReverb Light as "L1V" (look at the title bar in the effect).
The only reason it showed in the Effect menu as "Anwida Soft: L1V" in older versions of Audacity was because we sorted the effect list by vendor name.
If you want that old behaviour (which many thought was a "bug"), you can open the
Effects Preferences and choose the option to sort by publisher and effect name.
hans-jürgen
Post
by hans-jürgen » Tue Mar 08, 2016 3:57 pm
Gale Andrews wrote:It's a "bug" in the plugin, not Audacity. Anwida named the DXReverb Light as "L1V" (look at the title bar in the effect).
Yes I know, probably should have mentioned that. I wrote a related bug report to their Technical Support on their website today and already got a reply:
Re: Support request for DX Reverb Light
Thank you for your feedback.
A new release of the DX Reverb Light will be available shortly (within
the end of this month).
Best regards
Massimiliano Tonelli
Thanks for mentioning that option, I will do that for the time being.
