exporting multiple tracks at once
046oh
Post by 046oh » Mon Mar 03, 2014 4:14 am
i know about the export multiple option which exports files based on lables, but can i do a similar things based on tracks?
so say i have four tracks in my project, and i want audacity to export four .wav files for each of the tracks.
Re: exporting multiple tracks at once
Post by kozikowski » Mon Mar 03, 2014 5:29 am
I assume you mean one WAV for each of four tracks.
Try putting a label at the top of each track. File > Export Multiple.
Post by steve » Mon Mar 03, 2014 6:42 am
046oh wrote:i know about the export multiple option which exports files based on lables, but can i do a similar things based on tracks?
Yes. Select the tick box: "Split files based on tracks".
See here for details: http://manual.audacityteam.org/o/man/ex ... tiple.html
