pitch envelope
046oh
pitch envelope
Post by 046oh » Mon Mar 03, 2014 3:51 am
is there one in audacity?
if not, is there a way to achieve the same effect?
Re: pitch envelope
Post by steve » Mon Mar 03, 2014 4:44 am
There is a "Time Track" feature that may do what you want: http://manual.audacityteam.org/o/man/time_tracks.html
046oh
Re: pitch envelope
Post by 046oh » Fri Mar 14, 2014 1:24 am
thanks!
it did what i wanted, but i was wondering if i could make the time track affect only one track, not everything in my mix.
Re: pitch envelope
Post by steve » Fri Mar 14, 2014 10:46 am
Yes you can, sort of ;)
You would need to create the time track envelope (this will affect all tracks), then:
Select the track that you want it to affect.
Tracks menu > Mix and Render. This will "render" the selected track and in so doing will "apply" the time envelope to the track. The selected track(s) are "used up" (disappear) and a new "Mix" track is created at the bottom (below all other non-selected tracks).
Then delete the Time Track (click on the [X] in the top left corner of the track.
See here about "Mix and Render": http://manual.audacityteam.org/o/man/tr ... u.html#mix
