i know i can fit a window to a project, but can i resize so that it fits for a selection?
i have a short track in my project.
fit window for track
Re: fit window for track
Drag-Select a portion of your show and Control-E Zoom Into Selection.
Control-3 zooms out a little bit and Control-F zooms out full.
