Plug-In Request: 8-bit-ification
Using Nyquist scripts in Audacity.
Post and download new plug-ins.
MenDude
Post by MenDude » Wed Feb 26, 2014 4:46 pm
Hey there, I'm kinda new here, and I don't know any coding so...
I haven't found a plug-in that makes sound 8-bit like, so I'm requesting one here, in hope that someone can make one, please.
Thanks in advance.
Re: Plug-In Request: 8-bit-ification
Post by steve » Thu Feb 27, 2014 3:06 pm
Use the "Nyquist Prompt" effect (Effect menu) and paste this code into the text box:
Code: Select all
(quantize s 127)
When the number of "steps" is 127, then a signal that ranges from -1 to +1 will be quantized to 255 levels (127 less than zero, 127 greater than zero, and zero itself), which is equivalent to 8 bit audio.
MenDude
Post by MenDude » Thu Feb 27, 2014 5:20 pm
Is it the "Nyquist Command Line"?
(Using Audicity 2.0.5)
Post by steve » Thu Feb 27, 2014 7:26 pm
MenDude
Post by MenDude » Fri Feb 28, 2014 4:52 pm
Ah, so it is (sorry, I'm not English so Audacity isn't either :/ ).
