Following is the code that we tried for retrieving the time.
Code: Select all
;nyquist plug-in
;version 1
;type analyze
;categories "http://audacityteam.org/namespace#OnsetDetector"
;name "Beat Per Minute"
;action "BPM..."
;; Released under terms of the GNU General Public License version 2:
;; http://www.gnu.org/licenses/old-licenses/gpl-2.0.html
;control thresval "Threshold Percentage" int "" 65 5 100
(setf s1 (if (arrayp s) (snd-add (aref s 0) (aref s 1)) s))
(defun signal () (force-srate 1000 (lp (snd-follow (lp s1 50) 0.001 0.01 0.1 512) 10)))
(setq max (peak (signal) NY:ALL))
(setq thres (* (/ thresval 100.0) max))
(setq s2 (signal))
(do ((time 0.0) (listB NIL) (checkval 1) (belowThres T) (val (snd-fetch s2))) ((not val) listB)
(if (and(and belowThres(> val thres)) (= checkval 1))
(progn
(setq listB (cons (list time "B") listB))
(setf sampv1 (if (arrayp val) (snd-add (aref val 0) (aref val 1)) val))
(snd-srate sampv1)
(snd-t0 sampv1)
(setq checkval 0)
(if (and belowThres (< val thres))
(setq checkval 1)
(setq belowThres (< val thres))
(setq time (+ time 0.001))
(setq val (snd-fetch s2))
error: bad argument type - 0.469504
Function: #<Subr-SND-SRATE: #aa82998>
Arguments:
0.469504
Function: #<FSubr-PROGN: #aa7d750>
Arguments:
(SETQ LISTB (CONS (LIST TIME "B") LISTB))
(SETF SAMPV1 (IF (ARRAYP VAL) (SND-ADD (AREF VAL 0) (AREF VAL 1)) VAL))
(SND-SRATE SAMPV1)
(SND-T0 SAMPV1)
(SETQ CHECKVAL 0)
Function: #<FSubr-IF: #aa7d840>
Arguments:
(AND (AND BELOWTHRES (> VAL THRES)) (= CHECKVAL 1))
(PROGN (SETQ LISTB (CONS (LIST TIME "B") LISTB)) (SETF SAMPV1 (IF (ARRAYP VAL) (SND-ADD (AREF VAL 0) (AREF VAL 1)) VAL)) (SND-SRATE SAMPV1) (SND-T0 SAMPV1) (SETQ CHECKVAL 0))
Function: #<FSubr-DO: #aa7d6c0>
Arguments:
((TIME 0) (LISTB NIL) (CHECKVAL 1) (BELOWTHRES T) (VAL (SND-FETCH S2)))
((NOT VAL) LISTB)
(IF (AND (AND BELOWTHRES (> VAL THRES)) (= CHECKVAL 1)) (PROGN (SETQ LISTB (CONS (LIST TIME "B") LISTB)) (SETF SAMPV1 (IF (ARRAYP VAL) (SND-ADD (AREF VAL 0) (AREF VAL 1)) VAL)) (SND-SRATE SAMPV1) (SND-T0 SAMPV1) (SETQ CHECKVAL 0)))
(IF (AND BELOWTHRES (< VAL THRES)) (SETQ CHECKVAL 1))
(SETQ BELOWTHRES (< VAL THRES))
(SETQ TIME (+ TIME 0.001))
(SETQ VAL (SND-FETCH S2))
1>
The bad argument type that we are getting, is that something related to time? coz, in the code we have taken a new sound variable sampv1 for which we want the start time. When sound s2 goes above the threshold, the sound at that instance is intended to be stored in sampv1. Have we done it correctly?
