Hello,
I am seeking a self vocoder program to adjust my tune I'm sure it exists.
Because on iphone and android can find it self adjusts very rap your voice.
http://www.youtube.com/watch?v=k_xT9fhtWPU
search for one vocoder easy and auto
mikestjean
Re: search for one vocoder easy and auto
I can't watch YouTube right now 'cause I'm at work...
I don't think you are looking for a vocoder... I think you are looking for something like AutoTune, or Melodyne. These are profesional pitch correction tools.
There is a free plug-in called Gsnap and there are others.
If you are looking for a vocoder, I think it's one of the optional Audacity plug-ins. (There's one in my Audacity Effect list, so it assume it came with the LADSPA plug-ins.)
Robert J. H.
The vocoder is shipped with Audacity. It works pretty well, once you've got the hang of it.
- Quality Assurance
If you need help using the shipped Audacity Vocoder please see: http://manual.audacityteam.org/o/man/vocoder.html .
However I agree GSnap is what you need if you are trying to get the T-Pain effect.
