Can't open VXI USB microphone
This section is now closed
jimandy
Post by jimandy » Mon Dec 15, 2008 2:56 am
With either stable or 1.36 versions I get "error while opening sound device" using a VXI USB 7.02 "translator" interface with Cyber Acoustics microphone which works fine in Garage Band and on Skype. The device shows up in the Audacity Preferences pane for selecting the sound source and is selected.
Mac is Intel Powerbook Pro running OSX 10.5.5. I have re-installed, restarted, all the usual things.
Re: Can't open VXI USB microphone
Post by kozikowski » Mon Dec 15, 2008 3:28 am
Try Audacity preference settings of 44100 KHz, 16-bit, Mono.
USB Microphone
http://kozco.com/tech/audacity/USB_Microphone.html
jimandy
Post by jimandy » Mon Dec 15, 2008 5:09 am
That worked! Thanks kozikowski.
jimandy
