Audio Length
Help for Audacity on macOS.
emjay_uk_2000
Audio Length
Post by emjay_uk_2000 » Fri Feb 21, 2014 10:23 am
Hi all - is there any way to compress and audio's length?
I have a radio show I've put together and it's 1 hour 20 seconds and I want to compress it to 59 minutes 55 seconds (which won't affect the audio that much over an hour).
I thought I had done it the other day - but I've tried to play it again and realised that, to cut down the time, it's lopped off some of the beginning of the show!!
I really need help for this is you can! Really grateful!
MJ
Re: Audio Length
Post by kozikowski » Fri Feb 21, 2014 2:06 pm
Effect > Change Tempo.
That can cause sound damage. Effect > Change Speed will cause less damage, but the pitch of the performance changes.
Robert J. H.
Re: Audio Length
Post by Robert J. H. » Fri Feb 21, 2014 3:55 pm
I would first try to compress the pauses.
This is less audible. It is available under 'Effects', 'Truncate Silence'. It needs a little bit experimenting to find the right compression ratio and perhaps the threshold. Use it only on spoken passages.
