hello
os x 10.8.5 mac pro book audacity 2.0.5 dmg installer
hay ! hay ! hay ! maldita cabessa
yes ! Gale you are prefectly right , i did not notice i was on the spanish forum !
yes its steve harris plugin i did download thems , in witch folder i schould put thems to be abble to use thems ?
thanks very much
bonjour
bien sur Gale ! quel etourduis je suis , je ne me suis meme pas apercus que j'etais sur le forum espagnole !
oui ce sont les plugins de steve HARRIS
afin de les utiliser dans quel folder dois je les ranger ?
merci beaucoup
steve harris plugin
atomottokar
- Quality Assurance
Re: steve harris plugin
It says on http://audacityteam.org/download/plugins :atomottokar wrote:os x 10.8.5 mac pro book audacity 2.0.5 dmg installer
If you prefer, you can put them in ~/Library/Audio/Plug-Ins/LADSPA or /Library/Audio/Plug-Ins/LADSPA .To install new LADSPA or Nyquist plug-ins, place them in the Plug-Ins folder inside the Audacity installation folder.[...] On Mac OS X, it is usually under "Applications".
Then Audacity > Quit Audacity and restart Audacity.
atomottokar
hello
i do not see thems ? wrong placement ?
would you see the attachement
thanks
thanks
- Attachments
- Screen Shot 2014-02-21 at 10.08.22 AM.png (138.79 KiB) Viewed 3323 times
- Quality Assurance
The zip file http://audacity.googlecode.com/files/sw ... 0.4.15.zip is not an installer. The user is responsible for putting the extracted files in ~/Library/Audio/Plug-Ins/LADSPA if they wish to do so.
