Compile error analyze.ny
Since SVN r13054 i get this error:
make[2]: Entering directory `/home/hains/audacity-read-only/src'
cd .. && /bin/sh ./config.status src/configunix.h
config.status: creating src/configunix.h
config.status: src/configunix.h is unchanged
make[2]: Leaving directory `/home/hains/audacity-read-only/src'
make[1]: Leaving directory `/home/hains/audacity-read-only/src'
Making all in tests
make[1]: Entering directory `/home/hains/audacity-read-only/tests'
make[1]: Nothing to be done for `all'.
make[1]: Leaving directory `/home/hains/audacity-read-only/tests'
make[1]: Entering directory `/home/hains/audacity-read-only'
make[1]: *** No rule to make target `plug-ins/analyze.ny', needed by `all-am'. Stop.
make[1]: Leaving directory `/home/hains/audacity-read-only'
make: *** [all-recursive] Error 1
[email protected]:~/audacity-read-only$
r13053 was no problem. Ubuntu 14.04.
Making all in tests
Re: Compile error analyze.ny
analyze.ny has recently been removed from the source code (it was just a demonstration/example plug-in with no practical value).
To ensure that you are starting with a clean source, run:
then run:
to reconfigure the build options.
If you have a problem with the last command, try:
Note that autoreconf requires autoreconf 2.60 or later (should be available in your distro repository).
Code: Select all
make distcleanCode: Select all
autoreconf --no-recursiveIf you have a problem with the last command, try:
Code: Select all
autoreconf --no-recursive -i9/10 questions are answered in the FREQUENTLY ASKED QUESTIONS (FAQ)
That did not work. But i removed analyze.ny in the makefile(root) row 524 and now itś compiling again.
- Quality Assurance
Thanks, the removal of analyze.ny from Makefile.am has now been committed: http://code.google.com/p/audacity/source/detail?r=13057
frenchfries
Hello,
I just compiled Audacity for the first time, and had an issue concerning analyze.ny.
For Audacity to build without failing, I had to remove analyze.ny from the plug-ins folder in the Audacity VC++ project.
If you are using the current SVN checkout, analyze.ny is not present.frenchfries wrote:For Audacity to build without failing, I had to remove analyze.ny from the plug-ins folder in the Audacity VC++ project.
frenchfries
I may be confused since I am new to the project. I see that the file analyze.ny is no longer present, but it seems that the Audacity project still has a reference to it.steve wrote:If you are using the current SVN checkout, analyze.ny is not present.frenchfries wrote:For Audacity to build without failing, I had to remove analyze.ny from the plug-ins folder in the Audacity VC++ project.
I've attached a file which is a diff between the working base with the analyze reference, and what I had to change to make it work for myself.
- Attachments
- audacityAnalyze.png (143.1 KiB) Viewed 3356 times
- Quality Assurance
Analyze.ny has not yet been removed from the Windows MSVC project files, so as frenchfries says, Audacity won't compile on Windows without that change.steve wrote:If you are using the current SVN checkout, analyze.ny is not present.frenchfries wrote:For Audacity to build without failing, I had to remove analyze.ny from the plug-ins folder in the Audacity VC++ project.
If someone doesn't notice it soon, I'll remind them/suggest a patch.
frenchfries
Also, there is a reference to analyze.ny in the makefile.in file.
Should all references to analyze.ny be removed?
I've prompted the developers about this, but it was only about 48 hours ago that analyze.ny was removed. References in the various build systems are being removed.
