I have used my mouse to select a section of a track (it's highlighted in darker grey) but I cannot copy it - the copy function is greyed out.
What do I have to do to copy the section I selected?
v 2.0.2
Thank you!
Cannot copy selection
Re: Cannot copy selection
Press the Stop button.
Most of Audacity's commands are unavailable while playing, recording or paused.
Aaah - that's it - so simple - thank you!
