audacity command line access
bmende
Post by bmende » Wed Feb 05, 2014 9:48 pm
Could someone please tell me how I can access audacity from the command line? My desired parameter is simply the file name to open and I would like the program to start playing automatically. Any help much appreciated!
Re: audacity command line access
Post by Gale Andrews » Thu Feb 06, 2014 12:16 am
Audacity only has limited command-line support. The only current command-line functions are that you can open audio files or Audacity project files (including multiple files) by passing them as arguments, for example:
Code: Select all
$  audacity file1.aiff file2.wav file3.ogg
The following options are also supported:
-help
display a brief list of command line options
-version
display the Audacity version number
-test
run "Benchmark" diagnostics tests
-blocksize
set the Audacity blocksize for writing files to disk of nnn bytes
You can't tell Audacity to play the file. Probably you want to write an autohotkey script or similar.
Or if you can compile Audacity, try http://manual.audacityteam.org/o/man/scripting.html .
If you just want an application to play a playlist of files then you probably want a simpler solution anyway.
Post by Gale Andrews » Thu Feb 06, 2014 12:17 am
If you want to vote for more command-line options (without need to run Audacity scripting) please say what you are interested in.
bmende
Post by bmende » Thu Feb 06, 2014 1:46 am
Thanks much Gale. If more command line options could be added, I would vote for running in a minimized window, and one to start the audio without user click. Thanks again, Bruce
Gale Andrews wrote:If you want to vote for more command-line options (without need to run Audacity scripting) please say what you are interested in.
Post by Gale Andrews » Thu Feb 06, 2014 3:22 pm
bmende wrote:If more command line options could be added, I would vote for running in a minimized window, and one to start the audio without user click.
OK I'll record your vote.
Thanks.
rossmcm
Post by rossmcm » Sat May 30, 2020 1:01 am
If this thread is still alive, my vote would be for access to the export functions:
Code: Select all
audacity MyProject /exportWAV "Backing Vocals Track"  /exportWAV "Lead Vocals Track"
audacity MyProject /exportWAV *
where the tracks were referenced by their track name and the files were written to the current folder using the track name. Refinements could be allowing * to denote all tracks, or maybe supporting wildcard matches or regular expressions.
Also,
Code: Select all
audacity MyProject /exportWAV "Backing Vocals Track"  /exportWAV "Lead Vocals Track"   /exit
would allow Audacity to exit after all command-line operations had been carried out.
