Help
I've forgotten how to change the bit rate on a given project. Can someone help?
Bob H
Audacity 2.0.3
Windows 8
Bit Rate
- Quality Assurance
Re: Bit Rate
If you mean for MP3 export, in the Export window, choose "MP3 Files" then click the "Options..." button bottom right of the dialogue.rj7500 wrote:I've forgotten how to change the bit rate on a given project.
Audacity 2.0.3
Windows 8
If you meant bit depth (32-bit float versus 16-bit or 24-bit), look in the Quality Preferences under "Default Sample Format".
Re: Bit Rate
Thank you Thank you.........somedays I have more senior moments than others.
Bob H
Bob H
