analyse
Help for Audacity on macOS.
atomottokar
analyse
Post by atomottokar » Sun Feb 02, 2014 8:43 pm
hello
i cannot in the manual find infos on ANALYSE
je ne sais pas trouver dans le manuel d'informations sur ANALYSE .
thanks / merci
Re: analyse
Post by steve » Sun Feb 02, 2014 9:55 pm
Do you mean the Analyze menu? http://manual.audacityteam.org/o/man/analyze_menu.html
If you mean the "Sample Analyze Nyquist Plug-in", then that is just a test/demonstration plug-in. It just marks the start and end of the selection (nothing useful). It will be removed from later versions of Audacity.
