click / tempo
Help for Audacity on macOS.
atomottokar
click / tempo
Post by atomottokar » Sat Feb 01, 2014 5:06 pm
how to best pin point the spot to be repaired where a click appear ?
and
it would be “ fantastic if this or thoses samples point be color coded !
or automatically selected .
when applying “ tempo change “ l’attaque on somes notes [ piano ] become muddy is there a way to clean themes .
thanks to let me know on thoses
comment le mieux cerner les “ clcik “ afin d’etre reparer ?
et
cela serais fantastique que ce click soit automatiquement selectionner ou bien the samples code colore
lorsuqe “ tempo change “ est applique l’attaque sur certaines notes [ ex piano ] son deviennent par moment boueuse comment nettoyer ceux ci .
merci de vos reponses a ces questions .
Re: click / tempo
Post by Gale Andrews » Sat Feb 01, 2014 6:16 pm
atomottokar wrote:how to best pin point the spot to be repaired where a click appear ?
and it would be “ fantastic if this or thoses samples point be color coded !
See here: http://wiki.audacityteam.org/wiki/Click ... ogram_view .
atomottokar wrote:or automatically selected
If the click is above +/-1.0 on the scale to left of the blue waves, you can show the clicks with View > Show Clipping or Analyze > Find Clipping (which labels the clipping).
atomottokar wrote:when applying “ tempo change “ l’attaque on somes notes [ piano ] become muddy is there a way to clean themes .
Change Tempo may actually shorten notes or add little gaps. You can use Sliding Time Scale / Pitch Shift instead. It does not change the length but it takes longer to run the effect.
You should not Change Tempo by more than a few whole tones because it does change the audio quality. Changing the tempo should also change the pitch, so you are trying to do something that isn't "natural".
atomottokar
Re: click / tempo
Post by atomottokar » Sun Feb 02, 2014 9:52 am
hello very very usefull
i appreciate a lot .
thanks
atomottokar
Re: click / tempo
Post by atomottokar » Sun Feb 02, 2014 8:29 pm
hello
the spectogram is in black and white and not like the infos . see attachement
so ! again i don't where to look
thanks
bonjour
the spectogram est en noire et blanc . voir attachement
je ne sais donc ou chercher .
Screen Shot 2014-02-02 at 9.23.19 PM.png (196 KiB) Viewed 1388 times
Re: click / tempo
Post by Gale Andrews » Sun Feb 02, 2014 8:39 pm
atomottokar wrote:the spectogram is in black and white and not like the infos
Edit > Preferences, choose "Spectrograms" on the left. Uncheck (remove the mark from) the checkbox for grayscale (échelle de gris).
atomottokar
Re: click / tempo
Post by atomottokar » Sun Feb 02, 2014 8:48 pm
thanks a lot ! Gale
