Guidance for nyquist coding
Please state:
shravani
Post by shravani » Wed Jan 29, 2014 7:52 am
hello,
I m trying to add an option of determining the tempo ie. Beats Per Minute for a music clip. For that i am using Nyquist coding. I need guidance with the Nyquist coding. Can you please provide me with a proper manual which explains the Nyquist syntax in detail.
Hoping for a support as soon as possible.
Thanks in advance.
Re: Guidance for nyquist coding
Post by steve » Wed Jan 29, 2014 3:30 pm
This comes up a few times, so I've added a sticky topic in the Nyquist section of the forum: http://forum.audacityteam.org/viewtopic ... 38#p235338
Post by steve » Wed Jan 29, 2014 3:35 pm
Also, if you prefer to work with GUI programs, Scite is quite a good editor for Nyquist. It includes parentheses matching (essential for LISP based languages) and syntax highlighting for LISP. Note that the LISP syntax highlighting includes some commands that are not in Nyquist, and commands specific to Nyquist are not highlighted, but it is still close enough to be useful.
shravani
Post by shravani » Mon Feb 03, 2014 7:06 pm
Hello,
Thanks for reply. But help me to begin with programming in nquist. I don't have even slight idea about nyquist coding.
Thanks.
Post by steve » Tue Feb 04, 2014 10:34 am
Here's a couple of simple experiments that you can try. They will be a gentle (and practical) introduction to using Nyquist.
When you have tried these, have a look at the links that I posted previously.
If you have further questions (I'm sure you will ;)) please start a new topic on the Nyquist forum board (http://forum.audacityteam.org/viewforum.php?f=39)
Here are the experiments:
http://wiki.audacityteam.org/wiki/Nyqui ... the_Volume
http://wiki.audacityteam.org/wiki/Nyqui ... ependently
shravani
Post by shravani » Wed Feb 12, 2014 8:08 am
Hello,
I tried the examples. They are working fine.
While accessing the audio track, I want to save the amplitude and time of samples that are above a particular threshold. How can i do that? I had thought of using structure array the way we use in C language, but structure is not supported in Nyquist.
Please help me through this.
Hoping for a reply soon.
Thanks
Post by steve » Wed Feb 12, 2014 2:30 pm
steve wrote:please start a new topic on the Nyquist forum board (http://forum.audacityteam.org/viewforum.php?f=39)
