Keep getting error message about opening device??
Help for Audacity on macOS.
dancingletters
Post by dancingletters » Fri Jan 24, 2014 9:33 pm
I have Audacity 2.0.3. and Mac OS x10.8.5.
HI have attached the error message I keep getting. (Not sure how to get it to show up in this window).
It tells me:
Error while opening sound device. Please check the input device settings and project sample rate.
I have not used Audacity in many months and have forgotten a lot. I opened Audacity, plugged in my yeti, set the input and output to the yeti, recorded a bit, went back to listen then tried to record more. I keep getting the error message. I opened a new file with new track. What to do?
Thanks.
screen shot of the error message
Screen Shot 2014-01-24 at 4.23.36 PM.png (23.61 KiB) Viewed 633 times
Re: Keep getting error message about opening device??
Post by kozikowski » Sat Jan 25, 2014 12:20 am
You got the message the second time but not the first?!? Did you turn off or unplug the Yeti between the two tracks? Is the USB Device still listed in the Audacity recording list in the toolbar?
